Pacey
258
Northants
Hi Guys need your help..
PORSCHE 996 AND BOXSTER THE FRONTS ARE 8.5X19 AND ET 45 AND THE REARS 9.5X19 AND ET 45.
will they fit my cupra Tdi 150????
Thanks in Advance
do you have a pic? the fronts will be questionable as the smallest adapter is 15mm, the rears will also stick out past the arch.
they will fit and will look pretty cool but as said they will have some poke to them
as far as i new u was aloud the wheels sticking out what ever amount aslong as you cant see any tyre tred but on another club i bleong to a guy got his polo conficated by police because they was sticking out and the suspension was too stiff lmao complete joke if you ask me
depends on their ET the lower the ET the more they'll poke out
Also the offset of the stud holes on a leon is 5x100 whereas on a porker they're 5x130 so you'd have to have adaptors
I would say they are too wide, esp. the rear.
By the time you have fitted adapters they will be sticking out of the arches. Have you lowered the car, and how, on coilovers?
I have 19x8" front alloys ET45 with 10mm spacers and these clear the coilovers by a few mm and are just tuck inside the arch nicely - any wider (i.e. with the thicker adapter you will need AND the thicker alloy) and you will be clearly outside the arch too much and it will look silly as well as being illegal I believe.
Cheers for the input lads, nope not done anything to it yet but thinking of putting adjustable coilovers on it? Also seen some rs6 wheels they are only 18 but think they will fit a lot better and look pretty good? what you think???
