Window Regulator Replacement
smoggiecupratdi
45
Is this easy?
The passenger side front regulator appears to have gone on the drive into work this morning.
I'm trying to also lay my hands on the part as everyone I've tried in Stockton-On-Tees, is saying "we use genuine SEAT parts and they have to be ordered from Germany"
Andrewwright
Turbo lover
Aug 16, 2016
1,567
224
Peterborough
Is this easy?
Go to the scrap yard and buy a complete panel replacement and save the hassle of the kit. Scrap yard will be £10/20. First time is the worst and will probably take a few hrs
Sent from my Nexus 6 using Tapatalk
hombre_paulo
157
Or buy new cables from ebay for £7 and some butyl sealant (unless you`ve already done the door seals)
It takes next to no time extra to change the cables compared to the whole door carrier
Homer Simpson
229
22
https://www.ebay.co.uk/itm/FOR-SEAT...e=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
£21 brand new and delivered. I fitted it last month with no problems. I also bought another from them for a Bora, again no problems.
If you have not removed it before, it can be a bit fiddly but there is a guide somewhere. You may need to reseal it too. You can buy the complete panel but tbh if you are taking the panel out it's only 4 rivets extra and the old one is off.
verbal_kint
639
31
North West Kent
Is it easy? Yes if you follow the guides and take time. The worst part is getting the old sealant/foam cleaned off the carrier to ensure the new seal is good.
That ebay item Homer links to is good as they are the better metal clips and still miles cheaper than original.
sockpuppet
837
Here is the how to:
https://forums.vwvortex.com/showthread.php?1015107
I got the cables/clips and butyl from ebay. Putting the cables on isn't that easy as there isn't enough slack to get them over the guides. Easier option may be to buy the whole panel off ebay with the cables already fitted. While you have the door card off its worth changing the lock if this hasn't already been done.
