Wing Mirrors in 'L' position
2Stevo2
170
16
North Lanarkshire, Scotland
Guys,
Having read it on this forum, I learned that when you leave the mirrors in the 'L' position whilst reversing, it should angle downwards to help you park....
.....however....
Why do mine do the opposite?!?! It angles up the way to a position that is not helpful. Am i doing something wrong here?
When i put the switch to the middle position or take it out of reverse it goes back to the normal position.
hutchy14
65
Mines goes down to look at the kerb when I reverse. Check the settings as it needs to be enabled
hutchy14
65
Maybe try adjusting the position of them a bit the try it again
stu_m
613
40
Hull
www.themotorbikeforum.co.uk
I think you have to stick it in reverse then adjust the position to set it where you want and everytime you go in to reverse it will go back to that set position
dont quote me on that though
kazand
Is powered by Medtronics
Jun 6, 2010
4,138
73
Brum
↑↑^^ what he said
2Stevo2
170
16
Ahhhhhh....got to say that makes good sense. Think u might be right. Will giv it a go 2moro ;)
