Wing mirrors not folding when lock Cupra 290
noel2014
93
Tamworth
Hi.
Can anyone advise or help me. My wing mirrors were folding in fine when hold my lock button down on key fob. But all of a sudden from yesterday they have stopped folding when locking the doors. Any ideas ?
Alex_280
42
I'm not sure why it would suddenly stop working but there is an option on the infotainment system if you press the "car" one of the settings is for mirrors folding in when parked. If that is ticked then there is a thread in which someone had the same issues, reset their windows themselves and it cured the issue, I can't post URLs as I'm a noobie so I'll copy and paste the relevant info, credit to StevenM....
"I bet one or all of your windows won't auto-drop when you hold the driver's door window switch either? I had the same happen to me which I cured by resetting each of the windows. Ignition on, doors closed, using switches on drivers door, open each window individually holding it down for a couple of extra seconds when it's fully open, then immediately close it and keep the switch held for a couple of extra seconds when it's fully closed" it may take a couple of attempts.
Hope that works.
Feb 17, 2019
Hope that works.
Many thanks for sharing this. I realised today that my mirrors weren't folding and looked on this forum to see if there was a solution. I have a 2015 Cupra and I used your tip but it didn't seem to work after several attempts. A few more searches and I managed to find this worked for me instead:
1. Take drivers window down slightly then back up to top immediately. When it reaches the top, hold for one second the release the switch and immediately pull switch to close again and hold for just one second.
2. Repeat to all windows
After I done this my mirrors folded perfectly.
Your tip helped me find the solution however so hopefully mine will help others who may be struggling.
May 3, 2019
11
Thanks for sharing this Peter,
I have a 2015 FR and was at a loss until I tried this method.
Weird how it just happened out of the blue.
I blame McDonald’s drive thru...
Feb 17, 2019
Glad it helped WavyDavey. It was McD’s drive thru for sure, avoid in the future! I am KFC all the way and no problems here!
May 3, 2019
11
Haha Peter I agree on KFC 100%
Just a quick note, I ran OBD 11 earlier and it threw up an inactive fault with vehicle alarm so I’m wondering if that was the cause?
Never had that before or a problem with windows/mirrors.
I also noticed that the passenger LED on top of door was staying red when I was trying to fold mirrors with key before the reset.
Possible glitch with alarm but will keep an eye on it
Thanks again for your post
