Does someone know why xenons come with headlight cleaners and not normal headlamps?
its the law. they also have to be self leveling.
I never use my washers if its minus outside, untill there is a little temp in the engine to ensure the heat defrosts any fluid in the pipes of the washer. Parents had a VW Sharon and it burst the pipes because some stupid eajit kept the washer on when it was frozen..
Does your washers work when your engine is up to temp?
The heated mirrors come on when you turn the control knob to the center but they stay on so you have to twist the knob round to one of the mirror adjustment clicks to turn them off so mine were on for, oo about 6 months during the summer![]()
they only come on if the mirror knob is centre AND the heated rear winscreen is also on.
switch the rear screen off, the mirrors also go off.
Incorrect.Incorrect.
On as soon as you select the heated symbol in the centre of the two left right settings.
i will if you will......
I would stick them on to defrost them in the morning (along with rear screen) - then drive to the garage, get a coffee, restart the car - which now means the rear windscreen is off, and drive down the motorway for 50 miles .... heated mirrors still on![]()
All these variations in operation are weird on what's essentially the same car.
In my A3 manual, for example, it says that the heated mirrors come on/off automatically based on the exterior temperature![]()
