bertrum
Today saw the removal of the Mk3's wishbones prior to painting a poly-bushing... all was going well and typically, something had to go wrong...
Cracked off the rear bolt, when to crack off the front bolt... steady, steady, SNAP!
MotherF*cker [:@][:@][:@]:censored:
Snapped just over half way down so there's just that little bit too much bolt remaining to let the wishbone out.
Realistically, has this turned into a sub-frame out job?
Anybody had similar problems?
Snapped bolt...
happend to me to:blink: took a airsaw and cut the bolt so i chould get the wishbone out off the subframe.welded on a nute on the rest off the bolt that was sitting in the frame an heated up the subframe red hot:whistle:used a whrench and got it out:D
