Won't start after new fuel filter!
IxOZxI
112
Hey folks.
A reply ASAP would be great so I can get what I wanna do this afternoon done! But I replaced the fuel filter this afternoon, started it and left it running for a good 5-10 minutes no problem gave it a good rev and it was fine so turned it off. Now I wanna go out in it and it won't start! It's turning over but just not going! :( Anything anybody could think of to get it going?
Oz
IxOZxI
112
just tried filling it to the top with diesel and still no start so got a flat battery now lol. Going to use a set of jump leads and keep trying to turn it over, supposedly that's what should sort it according to my mate who's a bus mechanic
IxOZxI
112
Yeh, sorted it now. just had to turn it over for a while with the jump leads :)
Mar 25, 2009
1,245
bath
iirc you need to do a few ignition cycles to prime the filter before trying to start it
just as a not for next time :)
Sep 3, 2008
871
Buckie, Moray
Is there a lift pump anywhere on these engines for priming it?
On a Clio DCi there is a small pump near the filter so put the inlet hoses on the filter, pump until diesel comes out the out let hose and then fit these and pump a little more. Starts and runs no problem as youve flushed all the air out the filter
Lew89
309
Oxford
when i changed mine on my TDI FR i filled it with diesel prior to installing - started as if nothing had changed.
Stokie
Mk3 Leon Fr184
May 24, 2010
278
11
Stoke
Had to laugh when you said your mate whos a "bus Mechanic" i work for a bus compnay driving buses for a living & honestly these so called Bus Mechanics couldnt beat there way out of a wet paper bag, never mind fix a bloody bus :lol:
Modelmakerman
Mk4 Ibiza FR TDi
Apr 24, 2010
368
Bristol, UK
www.modelmakerman.com
The Ibiza has a pressurised fuel system so no need for a lift pump, the squirting noise when you turn the ignition on is the pump pressurising the system. As said above if you turn the ignition on and off a few times it will self prime the filter and injectors.
