Worrying issue
jackwoodcock
Today I went to town to grab some stuff to do my brakes, I drove back sensibly didn't give it any at all, when I got home I opened the bonnet and I could hear coolant bubbling? Water temp never goes over 90 or anything. Any ideas?
jackwoodcock
Ye levels all correct, il leave it running with cap off
wildrides
396
Thermostat may be stuck shut or the plastic impeller on the water pump has started spinning on its shaft or broken up entirely in bits ........... this causes localised boiling as no circulation
wildrides
396
The water gets hot and bubbles as no circulation as pump cant pump . Causes hot spots but not where temp sender is so does not always show on temp guage on short runs .
wildrides
396
err yes ............ On cupra R can change both pump and thermo externally ........ easy
on cupra thermo is external ....... pump behind cam belt ........ more involved ........ buy a golf MK IV haynes manual ( blue one ) or visit a garage if not capable of doing yourself
jackwoodcock
Any checks I can do for either so I don't just go changing parts for no reason
Azza_
526
South Shields
could also be the expansion tank cap not sealing, if it doesnt get upto pressure the coolant boils.
possibly a simple check would be to get the car upto temp and crack the cap you should get a hiss of pressure, BE CAREFULL NOT TO REMOVE IT FULLY AS PAIN AND SUFFERING WILL OCCUR
