tarzan
cupra owner from norway
Mar 15, 2008
1,122
drammen norway
got my TA-TECHNIX coilovers today but i the tuv paper it says ibiza 6k1 polo 6n1 and cordoba 6k2 i got ibiza cupra 6k2.with 865 front 760 back.the dealer sent after a document number two that says 900 front 790 back are they right or not what do you think?? the here are som pictures
front
bak
so just need so white grease and do it like on this picture from philW
in relation to your question..... you have got mk2 coilovers.. they wont fit mk3's as the top mounts are very different.
the rears you have will fit but the fronts wont... send the coilies back
post edited.. as mentioned below from cupramillo...
sorry :redface:
No don't send them back.
You should have also got 'fat' springs in the post. What you do is take off the 'thin' spring and that metal cup, then put the fat spring in it's place and fit to the top mount as it will fit nicely in the new fat spring ;)
got no fat spring :cry:
i want to put 40mm drop on my cordoba with apex springs... but was wondering if you have to upgrade the anti roll bars for this or not??? and if anything else needs to be done to the car for this??
