Your track setup's / handling brakes etc...
Dec 20, 2007
505
Hey guys, got my first track day 9th of april so im building towards that as the power is ok at the moment...
My spec im hoping for by april is
Weitec GT Coilovers
28mm Rear ARB
New front uprated discs (not sure which yet)
Audi TT Quick shift
All ready have
Ferado DS2500 pads
TOYO Proxes 4's
10mm hubcentric spacers
So basically anything else people think i should look into getting ? Hoping it will handle pretty well with those bits :)
Rob.
9,335
South Wales
Willwood 310mm 4 Pots with grooved discs, DS2500 pads, braided lines and Wilwood brake fluid with grooved rears.
3.684 final drive box with Quaife ATB diff
Front and rear ARB's. 28/25mm.
15mm rear spacers and front and rear strut braces.
215/40/17 Yoko Parada Spec 2's up front with 205's at the rear.
FK Silverline coilys
SPEC Stage 3 Clutch and Lightened Fly
Blackforest Stage 1 Engine mounts
Stripped out rear
2 x short shifters
And hopefully some seats and decent harnesses.
2,758
Brembo 4pot Calipers with braided hoses
"badger 5" 305mm grooved disks, DS3000 Pads, dot5 Brake fluid
Front/Rear ARBS 28/25 - 15mm rear spacers
Front strut brace
205/40/17s GSD3's all round
FK Highsport Coilovers
Front Sparco bucket seats, sparco frames with sparco Harnesses
Stripped out rear end, air con removed, etc etc :D
Off the top of my head, thats it brake/handling wise on mine
pdcupra
Ibiza-less
Aug 11, 2006
743
King's Lynn
Brembo Cupra R 4pot Calipers + S/S Braided Hoses
305mm Elliptical Grooved disks, DS2500 with Pads MOTUL RBF600 Fluid
Front/Rear Neuspeed ARB's 28mm Front, 25mm Rear
Seat Sport Front Strut Brace
3mm Front Spacers (To Clear Brembo's)
205/40/17s Toyo Proxes
Weitec Hicon GT Coilovers
that was the set up in my old one
TTS Roadsport
VAG specialists
Apr 24, 2006
229
Bedford
www.ttsroadsport.com
KW variant 3 Coilovers
H+R 25/28mm roll bars front and rear
Front upper and lower braces
Rear upper strut brace and a lower harness bar
Stripped out with carbon buckets and harnesses
205/40/17 Toyo R888 tyres all round on OZ Ultraleggeras
VW racing wishbones, rose jointed rear, nylon front
15mm rear spacers, 5mm fronts
Brembo 4pots with DS2500 pads and TT 256mm vented discs and calipers at the rear. Braided lines front and rear.
Peloquins LSD
Uprated engine mounts also help.
Ive got some rose jointed track rod ends to fit inverted too. Just waiting for new arms. This will help bump steer.
Also having some eccentric top mounts made and i still need to fit some rose jointed rear beam bushes.
Alex
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
330mm badger5 2-piece Disks
AP 4-pot CP5000 calipers on custom carriers
DS3000 front pads
Stock rear disks
Stock pagid rear pads
Motul RBF600 brake fluid
Braided front hoses.
Kw 2 ways
VT suspension bushes
Eccentric pherical bearing front top mounts
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
both imho... is 28mm rear... rear one first tho if doing them seperately, and or choosing 25mm rear instead to complement the already 23-20mm taper front.
its as much down to how you like your handling as anything.
me - I like tail endy car which I can steer from the rear on throttle balance.
ian_cupra
Fitted
Spax RSX coilovers
Tarox 6 pot's 300mm grooved discs
Tarox race pads
Braided front hoses
Rear 28mm Neuspeed ARB
20mm rear spacers
16" super turismos with 195/45/16 eagle f1's
Audi TT Quick shift
Front and rear strut braces
On the way
VT engine mounts
Front 25mm neuspeed ARB
16" Compomotive MO's with 195/50/16 R888's :)
May 2, 2006
2,758
sorry for all the questions, how did he mod it? cut a bit away? bend it?
[shouts at h17och] GET ON THIS THREAD [/stops shouting h17och]
really got me interested in this now, any info appreciated
TurboCupra
190
Worth a go for the money it costs, the upper one made jack all difference.. to be honest they make jack all difference on cars with rubber bushes/mounts anyway, not unless your the stig and actuall CAN notice the difference..
