zeitronix wiring help
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
ive been meaning to wire up the zeitronix for a while!
can anyone lead me to wher ei nead to connect following wires??
colour are where to find would help :)
1 RPM input
2 throttle position
3 wideband analog output ???
4 sensor ground (is that a normal earth)????
5 user input 0-5v
6 simulated narrowband 02 output
cheers
HoocH
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
1) engine speed sensor, front of engine, near flywheel
2) pedal potentiometer
3) doesn't have one as std - will need to fit wideband
4) normal earth
5) ?? some adjustable pot?
6) std lambda probe
h17och
Sep 1, 2005
3,504
Dunstabubble
cheers for that mork! anyone know colours for throttle position
when you say std lambda probe which wire do you mean?
what you mean by number 5?
thanks philW...will pm him now
HoocH
h17och
Sep 1, 2005
3,504
Dunstabubble
going by the wiring info from another thread (apexi one) are these right?
(rpm or inj) - Pin 102/T121 (bk/bl) - smaller ecu connector <<coil for rpm
(throttle sig, 0-5v) - P35/T121 (gy/bl) - larger ecu connector
are they correct for the rpm and throttle position?
cheers
