power gain with a blue flame on a LC
tris
The Daddy
Feb 25, 2005
3,493
Kent & Track Days
www.leoncupra.net
Can someone give me an idea of power gain on a blue flame with 3" down pipe and 100 cel sports cat
on a leon cupra
thanks guys did a search and found nothing very suprised this has not been asked before
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
for what its worth vagcom was reporting 10 g/s more with a catback and tip when i was comparing before and after runs, not 100% conclusive but shows an increase all the same. downpipe etc should show more, or at least make irt more driveable.
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
cat back makes no difference
3" DP and 100 cell cat make a great deal of difference! :yes:
BF fcuked up when i went there, so for one day i had cat back, and like i said it made only noise difference and then next day they did the 3" DP and sports cat and that made a world of difference... only other mods to the car were airbox and DV... so even on standard 225 map i felt a good difference!
id guestimate a solid 30lbs and 15bhp gain I got.
turbo kicked in 500 rpm earlier and held the power much better from 5k onwards!
DEFFINATELY worth the money! :yes:
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Assuming the same as Miltek/APR parts - good spool up, and less restrictive top end
Not sure they're as imaginative as James' suggestion (30lbft would be a lot) but will move the available torque lower down the rev range.
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
i only "guestimated" 30lbs because i felt a BIG difference with it! :yes:
tris u want close to 240bhp?... well u got 230 at jabba didnt you? and on msn when u asked wat increase u may get i said maybe 15bhp, and you said is that it!!! :shrug:
still think you should do it tho! :)
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
don't get hung on on peak numbers - it's still connected to an asthmatic turbo that is maxxed out.
it will make it more driveable because of the wider spread of torque, but unless you're increasing the boost, you can't see (much) of an increase in torque.
And if your existing map pretty much maxxed out the turbo, it can't push any more air through regardless.
As I stated - it'll lower the rpm your torque is available from (due to quicker spool up) and slightly increase top end.
or you can just add on bhp if it makes it easier to understand
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
tris just do it... i felt a GOOD difference and that was on standard map, so i would assume on a much more aggressive map you would feel the benifits even more! :)
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
tris just thought... have a search through the BF threads... you will see a review most ppl have said after they had theirs fitted!
