low boost, vag-com fault codes anyone help??
sargey
Escaped mental patient
Aug 16, 2006
324
Weston-super-crapland
as in turn ignition on, (not the engine) and you will hear a high pitch noise from the throttle body, when that stops its alligned. Unless someone can prove im wrong. lmao
karl.w
methanol junkie
Oct 26, 2005
606
Were any of these faults coming up when you had your old ECU on there?
he bought the ecu from me. I just want to say that there is not a thing wrong with the ecu. I had been using it myself with no problems at all but i wanted a standard one for a new remap to make the most of my new k03s turbo and other mods.
all you can do it get it back on vag-com and see what fault codes come up.
karl.w
methanol junkie
Oct 26, 2005
606
or it can be done with vag-com i think its block 60
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
tb alignment takes no time at all, maybe 15 secs, ive actually watched it with the piping off, the tb itself doesnt move at all, just the motor connected to it.
17956 - Boost Pressure Regulation Valve (N75): Open Circuit
P1548 - 35-10 - - - Intermittent
17526 - Oxygen (Lambda) Sensor Heating: B1 S2: Open Circuit
P1118 - 35-10 - - - Intermittent
16496 - Intake Air Temp. Sensor (G42): Signal too Low
P0112 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P602 - 35-10 - - - Intermittent
17536 Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
17658 - Fuel Level too Low
P1250 - 35-00 - -
1. Check the N75 is connected ok, make sure the wires havent broken as they are pretty thin.
2. Check your secondary Lambda probe is connected ok
3. Air temp sensor disconnected?
4. Don't worry about that one
5. Possibly a result of 1 and 3. A faulty or under reading MAF would also cause error this....
6. Put some fuel in the car
CupraTgirl
Model Behaviour
Nov 8, 2002
2,468
England
Visit site
When i reset the battery it didn't reset the ECU. Left it off for a good 5 mins!!! Reset everything but the fault codes.
When you say reallign the throttle body???? Wot do you mean. i don't think i've ever done this.
Mine is feeling a bit sluggish. last nite i had trouble going past my mate in a lupo gti. normally i'd fly past. Dunno wots wrong with it!!
You need to have your battery disconnected for about 10 minutes, connect it all back up, turn your ignition on (where just the lights come on) for about 3 minutes and you will hear a click and a buzzing kind of noise
Once you have done that it should be ok
CupraTgirl
Model Behaviour
Nov 8, 2002
2,468
England
Visit site
I never said there was a problem with it, i was just trying to eliminate things
Was only trying to help :(
cuprahoggy
Cheers for your help, where is the N75 and the air temp sensor?? thanks
cuprahoggy
hooked the car up to vag-com again tonight and only one of the faults came up this time which was
P1128 - 35-00 - -
cuprahoggy
can anyone show me where the maf and n75 are on a picture? thanks
cupra-c_ya
I love da boost!
Oct 4, 2004
716
devon
img124.imageshack.us
n75 valve looks like this fella
you will have to take your engine cover off, you will see the n75 as in the picture.
maf sensor is to the left of your air box, look at this to give you an idea
http://communityhosting.net/tdiclub/index.php/Mass_Airflow_Sensor
If I get chance ill take a pic for you later, but this should do the trick
karl.w
methanol junkie
Oct 26, 2005
606
take the engine cover off and and the n75 is to the right of the engine block
the maf is bolted to the airbox and joins onto the black rubber hose that goes down to the turbo (TIP)
cuprahoggy
got it off finally!! cleared codes and working fine now, will see if it happens again if not, will get a new maf! cheers
