Mozz
Hi all,
Right. Bear with me here
For the last few months I've had an intermittent problem with the temperature control (3 knob manual) in the car. Every so often, instead of pumping out whatever setting I asked for, it would decide to roast me by putting the hottest air it could through the fans. All the other controls worked fine, but even with the fans off you could feel this hot air coming through. Not so bad in winter, a nightmare in summer (turning on the aircon made no difference either way).
In addition, the recirculation switch was almost completely unresponsive. If it ever did come on, it was for no more than 10 seconds.
So, with a week or so left on my warranty, I finally got round to booking it in to Chesterfield Autoworld. They took the car to inspect the problem (which shows up in VAG-COM as some sort of electrical problem with the temperature control vane motor and the recirculation vane motor IIRC). After waiting around about an hour the guy returns, telling me that the problem is fixed, but that Seat do not cover it under warranty as it is changes to the software parameters (from what they showed me, I'm guessing it was the movement range of the vanes they changed), and not a component that requires replacing, so I'm now short about £40.
The recirculation certainly works, but I won't be too sure of the temperature control for another couple of weeks, it being an intermittent problem.
Anyone had a similar experience of warranty not covering software changes?
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
