Vag Logs from mapped Cupra R
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
umm,, 2200mbar = 1.2bar?
How does that work? I thought 2200mbar would be 2.2bar or do I have that wrong?
you have to deduct 1000mbar for atmospheric pressure
so when vagcom says 1900mbar...the boost is really 900mbar (0.9bar)
think the k03 would explode if the ecu requested 2bar :D
Dan Cupra R
The Yellow Sub
May 2, 2006
1,514
Reading
perhaps Dan does has something dodgy, like a fecked lambda sensor, might make the ecu pull it back? sorry dont know what values are normal for logging them.
Im hoping it is something like that rather than the Map, I'd be pi**ed if it were the map. T7ODD is the other member on here that has been mapped by P-Torque & experienced probs.
But Im not saying that its the map thats caused it. There have been a few other members on here that have have been mapped by same place (p-torque) and have found it very good, Evo2345 did IIRC?
acidstrato
Dec 9, 2004
5,942
did T7ODD ever go back to PTorque? the thing is if it was the map (which im not saying it is) there's only one place that could sort it out for you. other than getting a new map which you dont really wanna do
i know lots of things that can affect actual boost, but not so much that affect requested, also i remember Will saying that he was giving the mk3s a tried and tested map i think? but I'm not sure
Dan Cupra R
The Yellow Sub
May 2, 2006
1,514
Reading
Think its best to get it in & looked at. Its going in on 31st Jan for 40k service & to "hopefull" get all the problems sorted at the same time.
I think Ill have to wait until then to see what its saying then. Hopefully will all be sorted, Its frustraiting waiting all this time:cry:
Ill get all the suggested checked over plus Ill take my logs in with me as well, Hopefuly the SEAT techies will be able to sort it all for me.......
