Hi,
Bear with me on this one as I am trying to be as accurate as possible...
After posting that my car was misting up real bad in one of the many "condensation" posts, I came home from a day away with work to find the inside of my windows like the outside after heavy rain, went home after sitting in the work car park and they kinda cleared, 20 mins later I checked the car and they were are misted up again.
Checked all footwells, nothing, checked the boot and as you face the boot the left hand side carpet side panel was damp on the shelf part that sits behind the light cluster. The foam panels on the arch were soaking under the carpet panel and damp all along the bottom of this cloth panel right to the back of the seat.
The boot liner panel was also damp along the same edge.
I could not see where the water would come in so dried it all off with a hairdryer and went for a drive to clear the cabin of any dampness (baked with the climate on HI and fans on full) checked the boot again and could see no water runs or anything.
B4 going to work I opened the boot and checked and could see a small run of water down the plastic panel edge that meets the carpet panel next to the flap that allows access to the bulbs. Now the strange this is that at the top of the plastic panel is another panel of plastic that goes around the boot light and this is all dry, it looks as if the water run starts from nothing and I cannot see where it would be coming in.
Any idea's on where it could come in, the boot seal is fine and if this the water run would be seen on the boot panel and the panel with the boot light in?
It is under warranty but if I can find the entry point I would rather just mastic it and know it is sorted instead of multiple journeys to the Dealer
