Wow, check this out
Jun 28, 2001
1,533
yer hundreds of cobra ones.
obviously the make is cobra and they work well and pics are on their site sensors just need painting.
and they dont stop you from reversing into things just beep faster when your getting closer .
learn to drive!:)
Craig Senior
I've been Tango'd
May 24, 2004
1,099
Yorkshire
I got one like this
http://cgi.ebay.co.uk/Vauxhall-Meta-SR2-Targa-Easy-Fit-Parking-Sensors_W0QQitemZ320071172419QQihZ011QQcategoryZ10404QQrdZ1QQcmdZViewItem
Took about an hour to fit and works very well and looks discrete. I got it from Stoneacredirect on ebay for about £65.
Craig Senior
I've been Tango'd
May 24, 2004
1,099
Yorkshire
Wow, what a good idea, alough the other one is more gadgety, is this very effective near the corners of the car? or does it just to straight back motion?
Seems to cover the whole back of the car quite well as the sensors are angled out.
The small speaker that came with it has two small LEDs and I have put this above the rear window so when reversing you can hear the beeps and also see which LED is flashing so which sensor is detecting the obstruction.
I always found that the Leon is not the easiest car to reverse due to the small rear window and high back end. I used to reverse upto things and be sure that I was very close only to get out and find a 5 foot gap:banghead2
The hardest bit when fitting the sensors is removing all the plastic panels in the boot to get access to the reversing light wires.
willbatch
394
I would say its power feed comes from the reverse lights, fitted a few of these kits in my time lol.
