si.mcadam
Just fitted ali pedals to the FR (in the rain!)
The photos on the Audi forum are good but dont tell you the whole story...
http://forums.fourtitude.com/zerothread?id=2194350
The wiring loom connector on the top of the pedals is very stiff, also the reliese button should be pressed in hard. I snapped it off accidentally! so pliers came out.
The base of the pedal fits onto two steel pins on the floor. It will only break the tags off if you pull hard!
What you need to do is fit a small flat blade screwdriver into the two (hidden) slots in the base plate (Have a look on the replacement & you see what I mean).
The left slot lever the plastic release tag over to the right, twisting the pedal over towards the drivers door.
The right slot needs the plastic release tag pushed into the pedal, then pull up.
Really not very obvious....
SI
SI
I considered that but just couldn't decide between Bacofoil (quality finish)and Tesco Value range (weight saving)
