Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
i expect it will have some communication issues now vista is locked down alot.
Locked down in what way?
I've just discovered the battery's flat on my laptop so that's charging while I install the software, etc.
Right... 506 and 512.4 appear to work fine. The latest version (607) doesn't, but I suspect that's down to my cable.
However, functionality wise, I'm limited as I don't have a VAG car to test it on and I'm only using the generic OBD-II connectivity in it on my ST.
This is where i get confuddled!
If i was going to use it with a USB cable, where would be the best place to get them from that is reliable?
If you had a decent cable, the latest version should work?
Um... isn't that what I said?
anyone know if it works with version 409.1?
