studioeng
R.I.P. SXE. Hello Salsa!!
Feb 12, 2007
76
Dorset
www.byattsystems.co.uk
I have been looking around my local scrapyards for a few parts for my Beeza; but I can't find any scrappy's with Beezas... I don't know if thats a good thing, or a bad thing.
Does anyone know where I can get hold of some spare parts; for example the Driver's side parcel shelf panel as the hinge/clip is broken on mine. I also need a Driver's side glovebox and a new vent for the centre console (passenger side).
Any help much appreciated :)
im the same lol! i need both the things that hold the parcel shelf, and a new shelf, wing mirror backings painted, O/S/R light... beezas just dont break down i guess!
Well that's reassuring... Only trouble is, I is needing bits.... grrr
I've been to a couple of scrappys in my area, but they don't seem to have any Beezas at all. I heard about a website www.partfinder.com, I have tried looking up the Ibiza, but all I get is K&N air filters :confused:
wow! this is amazing to me! theres LOADS of beezas & dobas in my local scrappys! ill see if i can pocket anything 4 u boys!
Maybe we should start a shopping list. :lol:
If you feel like helping me out, could you give me a rough ball park estimate if you can locate the parts for me; how much for your time and sending the parts to me.
studioeng, I might be able to help with the air vent... pretty sure I've got a spare in the garage, will check tonight.
Cheers fella; if you don't mind loosing it.
Although... Having looked at the center console, I don't know if it would be easier to replace the whole lot; or just pull out and replace the broken vent (the tab that allows you to redirect the air flow is broken).
Im sure that they're (almost?) identical to a mk3 golf interior
Thought one of my vents had broken too but I just popped it out and it'd unclipped itself a the back
Cool, I shall have a look round for butchered Polos aswell :lol: Which model would I need to look for; the same age range as the MK2 Beeza??
On another note, is there anyway of sorting the headunit connections out, so it doesn't loose it's memory every time I turn the ignition off?? There is already ISO blocks connected, would that be standard or after market??
Also is there only two positions on the key; insert key-one click-dash lights up-second click-engine starts??
I have an O/S/R light but it has a few scratches on it.:(
