Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
Its worth remembering that there are loads of different factors when it comes to MPG.
Fuel: Different fuels DO give better/worse MPG. Additives can help if the fuel is decent to start with.
Tyres: Differebt size and width of tyres have big effects on MPG. the wider or bigger the tyre, the more surface area on the ground and the more friction for the car to overcome.
Weather: The weather can make a difference. Cars run better on cold damp mornings than hot dry ones.
Driving style:If you hammer the car, it will drink more fuel. If you keep the car in the peak torque range it will drink less. Sticking to top gear in a 40mph zone isn't always the best way to increase MPG.
Distance: If your driving a couple of miles to work and back your MPG will suffer as the car won't warm up very quickly.A longer journey will see better MPG overall.
Age of car: The thing most people forget when buying a diesel is the condition of the engine. It may be brand new, but that means it's tight and still has some loosening off to do before MPG increases. There are lots of figures being thrown around on what milage you car should have loosened up by. I think 20k is somewhere near the start of it.
i have the 2.0 PD i normally use bp. bp fuel any good?
I have just tipped over 5k so i guess my mog will still increase?
As i am new to TDI's and not really clued up, what is the best way to increase the mpg? i do mainly long distance driving. Also where is the peak torque range ?
thing with me is that i have no computer so cant track changes in mpg while on the road, only part way or after a tank working it out, counting fingers and stuff.lol. any other way to track it more accuratly?
Thanks, will try the site, been working it out, but prob bit crude not knowing proper amount of fuel in tank etc. Was also looking for a way of tracking as a live update as am driving of engine performance. maybe VAG-COM or something, or get a new instrument with a computer!be expensive though!
