and we are talking about 'login' not 'recode'
sorry, my mistake should make myself more clearer.
i did this through recode - 07
a bubble came up with the suggested recoding, which was 00064 for central locking with power windows
i've emailed the sellers of the KVW100 to check compatibility with my car, and they say it won't work!? Surely if i can close the windows with the key on the lock, there must be a way to turn on this feature??
You have 2 options on the windows.mine also does this, hopefully seeing someone with a VAGCOM in the next few weeks, will i have to buy the KVW100 or can some settings be changed to allow this??
From personal experience I'd rather go with the AutoWindow kit. Sure it needs some hardware adjustments/tweaks but it also will never screw your comfort control module as it has been seen from the KVW100...
What faults have you seen from from this unit?
I've not heard of any myself, but if someones control module has been damaged by this then it's good to warn people.
Think most of them already have this? Mine doesOn the Golfs/Audi's you can also set the miles to empty feature, not sure about Seat though.
