__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Ok so just when i thought the car was back upto scratch after im pretty sure the soapy water trick has stopped my clutch from slipping, Ive got a knocking sound coming from what seems to be around the handbrake/gearstick area, Strange thing is tho its only doing it when i corner fairly hard to the left wondering if anybody has any ideas of what it could be or what i could check. Last week when i was cleaning the inside of the car i found what looks like an 8mm nut down by the passenger seat ive had quite a good search and cant find where it has come from maybe this could be the cause of the knocking?? :confused: When ive recoverd from my hangover and its stopped raining ill get a pic up of it.
David.
possible that an exhaust mount has dropped, and the exhaust is catching on the shell
I think the 8mm nut in the car might well not be related though
Mark
Ok cheers Mark. I shall have a look in abit. How would i go about fixing it if it has dropped? s it a re-weld or just a matter of tighting it up etc....
David.
Had this on mine, i'd get under there and look at the exhaust bracket. Give the exhaust a shake and i'm sure you'll see where its knocking. Easy fix :)
Still havent managed to get out under the car with this crappy weather, Glad to hear it should be a relatively easy fix.
David.
I had the same issue...just took it to kwik fit and had it up on a ramp as it was raining like today -
although mid week i reversed in to bay and the exhurst hit the curb - cracked the centre pipe - dealer asked for £150 for a new one - i went for the welding option - job done!
And it was just somthing to do with the bracket?
David.
