just got back from resetting ECU, TB alignment and playing with vag com... here are my results
no error codes came up
and as for boost...
1st gear, max requested boost: 12.7psi, max delivered 10.5psi
2nd gear, max requested boost: 19.7psi, max delivered 15.3psi
3rd gear, max requested boost: 19.1psi, max delivered 17.5psi
4th gear, max requested boost: 16.9psi, max delivered 16.6psi
5th gear, max requested boost: 16.6psi, max delivered 16.3psi
im not sure if the boost is lower because i just reset the ecu, but it does normally boost higher in 4th and 5th...
there defo isnt a boost leak, as in 3rd through 4th, the actual boost holds with the requested perfectly
also... i believe my revo settings are (on the old sps 3) lb9 t4 5 or 6... cant remember
as for the n75 duty... logged 118... not sure if it was correct tho... here are results
Code:
Saturday 10 March 2007 15:16:42
6K0 906 032 AA 1.8L 20VT EU3 0002
Group A: '118
RPM Temperature Load Absolute Pres.
TIME
MARKER STAMP /min °C % mbar
0.35 840 36 0 1030
0.73 840 36 0 1030
1.13 840 36 0 1030
1.53 840 36 0 1030
1.93 840 36 0 1030
2.33 840 36 0 1030
2.73 840 36 0 1030
3.13 840 36 0 1030
3.53 840 36 0 1030
3.93 800 36 0 1030
4.33 840 36 0 1030
4.73 840 36 0 1030
5.13 840 36 0 1030
5.53 840 36 0 1030
5.93 840 36 0 1030
6.33 840 36 0 1030
6.73 840 36 0 1030
7.13 840 36 0 1030
7.53 840 36 0 1030
7.93 840 36 0 1030
8.33 840 36 0 1030
8.73 840 36 0 1030
9.13 840 36 0 1030
9.53 840 36 0 1030
9.93 880 36 0 1030
10.33 920 36 0 1030
10.73 1120 36 0 1030
11.13 1520 36 0 1030
11.53 1800 36 0 1030
11.93 1680 34 0 1040
12.33 1360 34 0 1060
12.73 1480 33 0 1060
13.13 1760 33 0 1060
13.53 2120 33 0 1070
13.94 2440 32 0 1100
14.33 2800 30 0 1160
14.74 3280 30 0 1330
15.24 3840 29 1.2 1340
15.75 3560 27 0 1210
16.14 3000 27 0 1100
16.53 2640 29 0 1030
16.93 2680 29 1.2 1230
17.33 2880 29 1.2 1340
17.73 3120 27 1.2 1340
18.13 3360 27 1.2 1330
18.53 3600 27 55.7 1390
18.93 3960 27 82.4 1810
19.33 4360 27 95.3 2140
19.73 4720 27 94.9 2060
20.13 5040 29 93.7 1960
20.53 5320 30 94.5 1870
20.93 5120 32 0 1900
21.33 4440 30 0 1200
21.73 3680 30 95.3 1080
22.23 3920 33 95.3 1970
22.65 4120 34 88.2 2260
23.14 4320 36 92.5 2230
23.54 4480 37 92.9 2160
23.94 4640 39 93.3 2090
24.34 4800 39 93.3 2030
24.74 4960 42 91.8 1990
25.14 5080 44 91.8 1940
25.54 5200 45 91.8 1910
25.94 5280 46 91 1900
26.34 5000 46 0 1580
26.74 4360 43 0 1170
27.14 4240 42 77.6 1030
27.54 4200 42 95.3 1500
27.94 4280 45 95.3 2150
28.34 4360 46 92.5 2210
28.74 4440 47 93.3 2180
29.23 4520 48 92.9 2160
29.63 4600 49 92.2 2130
30.03 4640 50 91.4 2110
30.43 4720 51 90.6 2080
30.83 4760 51 90.2 2060
31.23 4800 52 89.4 2060
31.63 4880 53 88.6 2040
32.03 4920 54 88.2 2020
32.43 4960 54 87.1 2010
32.83 5000 54 86.3 1980
33.23 5040 55 85.5 1970
33.63 5080 56 84.7 1970
34.13 10200 589.05 5080 56
does n75 look ok?? i dont know
