i vag com'd imne a while ago, an didnt show any error codes. mine has alwas boosted like this since i got it revo'd
think il do another scan today, then do some logs,
can i check, what r the blocks for boost (requested vs actual)
and n75 duty??
tom
Great mate let us know how you get on. ive just got back from a test drive after i disconected the battery and did a TB alignment. As i thought didnt make any differance lol, im beginning to think its normal as we all have the same symptoms and have revo? my car still feels just as quick. admitdly i done a 1st gear launch and only hit 14psi:confused: surly thats not normal? but if i was to boot it in 2nd say from 20mph id get full boost but if i held the revs at about 40mph and planted it id only see 16psi and not a full boost.
Grrr its doing my nut! I need vag com :(.
david.
just PM`d Revo Kev so hopfully he might be able to shed some light on it when he arrives.
just got back from resetting ECU, TB alignment and playing with vag com... here are my results
no error codes came up
and as for boost...
1st gear, max requested boost: 12.7psi, max delivered 10.5psi
2nd gear, max requested boost: 19.7psi, max delivered 15.3psi
3rd gear, max requested boost: 19.1psi, max delivered 17.5psi
4th gear, max requested boost: 16.9psi, max delivered 16.6psi
5th gear, max requested boost: 16.6psi, max delivered 16.3psi
im not sure if the boost is lower because i just reset the ecu, but it does normally boost higher in 4th and 5th...
there defo isnt a boost leak, as in 3rd through 4th, the actual boost holds with the requested perfectly
also... i believe my revo settings are (on the old sps 3) lb9 t4 5 or 6... cant remember
as for the n75 duty... logged 118... not sure if it was correct tho... here are results
Code:
Saturday	10	March	2007	15:16:42
6K0 906 032 AA 		1.8L 20VT EU3       0002
	Group A:	'118
		RPM	Temperature	Load	Absolute Pres.
	TIME
MARKER	STAMP	 /min	°C	%	 mbar
	0.35	840	36	0	1030
	0.73	840	36	0	1030
	1.13	840	36	0	1030
	1.53	840	36	0	1030
	1.93	840	36	0	1030
	2.33	840	36	0	1030
	2.73	840	36	0	1030
	3.13	840	36	0	1030
	3.53	840	36	0	1030
	3.93	800	36	0	1030
	4.33	840	36	0	1030
	4.73	840	36	0	1030
	5.13	840	36	0	1030
	5.53	840	36	0	1030
	5.93	840	36	0	1030
	6.33	840	36	0	1030
	6.73	840	36	0	1030
	7.13	840	36	0	1030
	7.53	840	36	0	1030
	7.93	840	36	0	1030
	8.33	840	36	0	1030
	8.73	840	36	0	1030
	9.13	840	36	0	1030
	9.53	840	36	0	1030
	9.93	880	36	0	1030
	10.33	920	36	0	1030
	10.73	1120	36	0	1030
	11.13	1520	36	0	1030
	11.53	1800	36	0	1030
	11.93	1680	34	0	1040
	12.33	1360	34	0	1060
	12.73	1480	33	0	1060
	13.13	1760	33	0	1060
	13.53	2120	33	0	1070
	13.94	2440	32	0	1100
	14.33	2800	30	0	1160
	14.74	3280	30	0	1330
	15.24	3840	29	1.2	1340
	15.75	3560	27	0	1210
	16.14	3000	27	0	1100
	16.53	2640	29	0	1030
	16.93	2680	29	1.2	1230
	17.33	2880	29	1.2	1340
	17.73	3120	27	1.2	1340
	18.13	3360	27	1.2	1330
	18.53	3600	27	55.7	1390
	18.93	3960	27	82.4	1810
	19.33	4360	27	95.3	2140
	19.73	4720	27	94.9	2060
	20.13	5040	29	93.7	1960
	20.53	5320	30	94.5	1870
	20.93	5120	32	0	1900
	21.33	4440	30	0	1200
	21.73	3680	30	95.3	1080
	22.23	3920	33	95.3	1970
	22.65	4120	34	88.2	2260
	23.14	4320	36	92.5	2230
	23.54	4480	37	92.9	2160
	23.94	4640	39	93.3	2090
	24.34	4800	39	93.3	2030
	24.74	4960	42	91.8	1990
	25.14	5080	44	91.8	1940
	25.54	5200	45	91.8	1910
	25.94	5280	46	91	1900
	26.34	5000	46	0	1580
	26.74	4360	43	0	1170
	27.14	4240	42	77.6	1030
	27.54	4200	42	95.3	1500
	27.94	4280	45	95.3	2150
	28.34	4360	46	92.5	2210
	28.74	4440	47	93.3	2180
	29.23	4520	48	92.9	2160
	29.63	4600	49	92.2	2130
	30.03	4640	50	91.4	2110
	30.43	4720	51	90.6	2080
	30.83	4760	51	90.2	2060
	31.23	4800	52	89.4	2060
	31.63	4880	53	88.6	2040
	32.03	4920	54	88.2	2020
	32.43	4960	54	87.1	2010
	32.83	5000	54	86.3	1980
	33.23	5040	55	85.5	1970
	33.63	5080	56	84.7	1970
	34.13	10200	589.05	5080	56
does n75 look ok?? i dont know
Might be worth posting these results up in the Vag Com section mate im sure sombody there will have a good idea.
David.
can we see actual vs requested for our selves
when logging you cant just log for a few seconds in each gear, you need low rpm to redline, otherwise its useless
funny though, according to that log your car revs to 10200rpm
hahaha... yeh, my vag com does sometimes spaz out towards the end of logs!! im pretty sure it didnt rev that high
i know ur meant to log from like 2000rpm-6000rpm... but for this i did a lo from pulling away in first gear and accellerating rightn through the revs...
Code:
Saturday	10	March	2007	15:14:34
	Group A:	'115
		RPM	Load	Absolute Pres.	Absolute Pres.
	TIME
MARKER	STAMP	 /min	%	 mbar	 mbar
	0	840	17.3	1020	1030
	0.4	840	17.3	1020	1030
	0.8	840	17.3	1020	1030
	1.2	880	18	1020	1030
	1.6	1120	27.8	1020	1030
	2	1280	33.1	1020	1030
	2.4	1200	43.6	1020	1030
	2.8	1320	50.4	1020	1040
	3.2	1080	54.9	1020	1050
	3.6	1160	63.2	1020	1060
	4	1360	60.9	1020	1070
	4.4	1600	56.4	1020	1070
	4.8	1880	55.6	1020	1070
	5.2	2160	58.6	1020	1080
	5.6	2440	60.9	1020	1100
	6	2760	59.4	1020	1120
	6.4	3120	76.7	1020	1150
	6.8	3560	80.5	1080	1350
	7.18	4120	98.5	1340	1310
	7.6	4720	121.1	1680	1370
	8	5520	140.6	1890	1740
	8.4	6000	133.8	1020	1650
	8.8	5320	9.8	1020	1290
	9.2	4160	42.9	1180	1070
	9.6	3880	118	2370	1410
	10	4200	163.2	2290	2050
	10.4	4560	169.9	2170	2070
	10.8	4880	163.9	2040	1960
	11.2	5160	155.6	1940	1870
	11.6	5440	147.4	1880	1810
	12.09	5720	139.1	1790	1740
	12.49	5480	10.5	1020	1340
	12.89	4840	63.2	1410	1040
	13.29	3960	129.3	2330	1560
	13.79	4120	172.2	2270	2220
	14.19	4280	173.7	2220	2210
	14.6	4440	170.7	2180	2150
	15	4600	168.4	2110	2090
	15.4	4720	166.2	2060	2040
	15.8	4840	163.9	2020	2010
	16.2	4960	160.9	1970	1970
	16.6	5080	159.4	1940	1940
	17	5160	155.6	1910	1910
	18.6	6000	51.9	1020	1950
	19.1	4160	94	2060	1090
	19.59	4400	158.6	2180	2030
	19.99	4480	169.2	2160	2160
	20.49	4560	169.9	2120	2130
	21	4640	168.4	2090	2110
	21.4	4720	166.9	2070	2090
	21.8	4760	166.2	2050	2060
	22.18	4840	163.9	2030	2040
	22.58	4880	163.9	1990	2020
	22.98	4960	162.4	1970	2000
	23.4	5000	161.7	1960	1980
	23.78	5040	159.4	1950	1980
	24.18	5080	160.2	1940	1950
	24.6	5120	158.6	1930	1950
	24.98	5160	156.4	1930	1940
	25.38	5200	154.9	1910	1920
	25.78	5240	154.9	1910	1900
	26.18	5280	152.6	1900	1900
	26.58	5280	150.4	1890	1890
	26.98	5320	149.6	1870	1890
	27.38	5360	149.6	1860	1860
	27.78	5400	147.4	1860	1870
	28.18	5440	145.9	1850	1870
	28.58	5480	144.4	1840	1860
	28.98	5480	145.1	1830	1840
	29.38	5520	143.6	1830	1840
	29.78	5560	142.1	1830	1840
	30.2	6120	68.4	1020	1960
	30.69	5160	58.6	1800	1080
	31.09	4480	142.1	2160	1760
	31.59	4520	168.4	2150	2130
	31.99	4560	169.2	2130	2140
	32.39	4600	167.7	2120	2140
	32.79	4640	168.4	2100	2120
	33.28	4640	166.9	2090	2110
	33.68	4680	167.7	2080	2090
	34.08	4680	166.9	2070	2080
	34.48	4720	166.2	2060	2080
	34.88	4760	165.4	2050	2070
	35.28	4760	165.4	2040	2060
	35.68	4800	163.9	2030	2050
	36.08	4800	163.2	2020	2050
	36.48	4840	163.2	2020	2040
	36.88	4880	163.2	2010	2020
	37.28	4880	163.2	2000	2020
	37.68	4880	161.7	1990	2010
	38.08	4920	160.2	1980	2010
	38.58	4960	160.2	1970	1990
	38.98	4920	72.9	1060	1790
	39.38	4920	21.1	1020	1230
	39.78	4840	9	1020	1130
	40.18	4800	8.3	1020	1090
	40.58	4760	8.3	1020	1080
	40.98	4680	9	1020	1080
	41.38	4640	9	1020	1070
	41.89	4480	9	1020	1070
	42.29	4440	9	1020	1070
here are graphs to make it clearer
I have what sounds like exactly the same syptoms and i could proberly say 98% that my actuator hasnt been touched as the car was compleaty standard when i got it, What could the other possibilitys be?
David.
