Pimp my vario
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
main.php
main.php
main.php
main.php
main.php
main.php
main.php
main.php
main.php
main.php
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
As you can see - it's in, connected to the wheels, front end is back on, coolant hoses are connected - all but one power steering line is connected (but it's a bit buggered, so will need replacing I think
Wiring loom is laid roughly in place, and connected in places (battery is in holding it down)
Tomorrow is wiring, and downpipe
God damn I impressed myself - engine was out by 10am, and then Jonah popped by and I jetwashed the engine bay, then after fitting F2-Stu's old manifold We pushing it back, lifted up onto the mounts & Job done!
WeeJase
pert
Jun 2, 2001
8,595
good job mate.deffo need something next with more lugging capacity,fed up of taking my wheels off to lug my bike :rolleyes:
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
That's got to be some kind of record. :clap:
I think I could have had it running today as well had I not run out of rapist gloves & energy
Still, been to B&Q and now have a hole cutty thing to put some holes in the bulkhead (under the ECU) for the wiring loom to drop into the fusebox below
The plan is to plug 'everything' in then work out what electricals aren't working (I've got 2 complete wiring looms in the car, and am not removing the 'old' one)
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Also worth noting was the subframes I used were the original ones - the rear is identical, just used the mounts from the engine.
The front I was all set to use the old subframe from the coupe, as it has cut outs etc for various parts - but I hit a snag that the vario's chassis leg mounts were about 1" narrower and 2" further forward than the coupe's (it's not a bent car...)
So I used the Vario's one - and it mounts just fine. (so same as 1.4 etc)
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
I'll spend tomorrow wiring it into the ignition, just to 'test' fire it - Stu's heading north too - so I'll see if he feels like swapping my rear beam
hopkinsgm
Do-doo-be-do-do-dooo
May 25, 2001
2,030
Swindon (occasionally)
Visit site
Looking good matey (the car, not you:D) - will be interesting to see how the rest of it goes.
Prior experience of engine swaps on lesser vehicles tends to suggest sorting the oily bits is usually comparatively simple, it's the electrics that tend to get traumatic. Using both looms ain't such a bad idea, but could get a touch messy. Hope there's no tricky interlocks to trip you up - which is something I've fallen foul of in the past.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
dash isn't coming out though Flapper, I've never got one out without breaking it yet, so I'm running it under the wipers & down instead
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Damn you!
No interesting progress photo wise today.
Stu arrived, and we've mounted the downpipe (dropped rear subframe) - then I set about wiring, while Stu did the rear beam for which I'm very grateful for his help!
Wiring was OK - I even had dash lights, stereo & working windows. So I wound them down, as it was very warm. then messed about some more & it won't wind up now! hey ho. that's a job for tomorrow now.
F2 Stu
I. Am. Legend.
Oct 4, 2001
5,577
Crawley, UK
Visit site
No windscreens were harmed with todays spannering:D
Would of liked to have got that beam fully bolteds up and connected but its only another loose ends to the list.
