Ok i keep getting the engine management light on. Really starting to bug me now, so i thought i would see if anyone could suggest why its on, and what i can do to fix it....
Brief senario.....I have APR ST2, full blueflame system, on a 52 LCR. I clear it with VAG COM, and it can be 2 days before it throws the light again, it mostly does it on idle, or at slow speeds, ie 4th gear 30MPH. I had no problems, but as soon as i filled up with tesco 99 i had the light on withing 3 mins, this was a mixed tank of V Power and Tesco 99 at 50/50 mix. The car is fine to drive, does not seem down on power, but occasionally, and it may be me imagining it, when on boost lightly say 5-7psi it may seem a little stuttery but nothing really noticable. Now i thought APR maps, had codes to keep the Lambda's happy, or am i wrong? And am i right in assuming (after searching) that B1 S1 is pre cat on the DP??
The fault codes.
2 Faults Found:
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-00 - -
17511 - Oxygen (Lambda) Sensor Heating: B1 S1: Performance too Low
P1103 - 35-10 - - - Intermittent
so what should i do? And what do the fault codes mean, I know J@mes has said about gapping the lambda, but im sure APR dont have this issue, Is it fried? could it have been some crap fuel, or just wear and tear..Any thoughts much appreciated.
Matt
The fault codes.
2 Faults Found:
P0130 - 35-00 - -
Matt
still need to clear the fault code off, but the car feels so much better now on just the short drive home, and the D/P isnt as loud now either
