Τhe beep sounds because the sensor "thinks" that the brake fluid level is low . But when you check the level , you will find out that you are ok . Just ignore the beep and keep turning !!
and the fun part is, when you go to your seat dealer and they plug it in they can tell you've been cornering hard!! (well according to my local dealer)
Mite be worth checking the wear on your pads too, if your brakes fluid is getting low it mite be due to excessive pad wear, or worse case scenario you could have a brake fluid leak, which would obviously be very very bad!!!
