i wanna put NOS in my car(a 2.0 tdi) but i have some questions
1. it is a special kit, or any kit should do the work
2. where it is injected ? in the airbox? or on the intercooler?
can u post some pictures pls or send them to me, becouse here in romania nobody did it and i'm planning on doing on my car
thanks a lot
Got your solenoid in a good spot there.I couldn't get anything similar, so mine is down where the battery was, and it injects into the inlet about 3 feet before the inlet. It should all hopefully still go in the same place though.
Mike - Is a "100" shot a 50hp? Which one do you use now?
My system is tight thankfully. Took some work on the gauge fitting to get it tight. liquid soap is quite good for finding leaks as it bubbles up on even the slightest tiny escape.Tested it out on Saturday and the system held 700 PSI. Turned the bottle off to be safe, and the gauge (external from the bottle obviously) is still reading 700 PSI even now.
I think I will go with the 100 shot first, although I have a 50 shot too. Wonder whether I should get myself a 75 one though?
I got my bottle filled first time by a chap in Bournemouth, as I was down there anyway at a show (found through the WON forum) Not sure who does them locally but I understand a place in Cullompton does them - local to you.
The leak on my bottle is between the bottle and on/off valve which came already joined from WON. The place on the WON site near me closed down years ago and is now a TVR tuning garage that has nothing to do with NOS, seems like posting the bottle is the only option really. Answer your dam mobile as well mate as i just tried to phone you.
