Dave theyre for my calipers to the hub fitment, so whatever you reccomend really.
Total length of thread is 40mm - then a shaft length of 25.5mm(same dia as the thread) So a total of ~65mm length from end to the head.
17mm hex head would be fine.
Thanks.
You need 4, Phil?
M12 has a 19mm hex head and usually 1.75 thread pitch - so 1.5 is Fine.
Is 19mm head and 1.5 ok?
That's the thing, I'm running a K03S which I think is being pushed to its limits. The bottleneck is the turbine. There's an awful lot of heat trying to go through that little hole into the turbo. I have an ATP exhaust manifold which is taller than standard.So Dave, do you have an aftermarket turbo?
