Pimp my vario
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
G, is this for the Fiat, or the Ibiza? I'm sure once I've set mine up and I know it works I won't mind lending it out.
Anyway
remembered at 4pm I had an immobile car on the drive, so thought I'd best stick some bits on
Exhaust fitment is 'interesting' but the back box & centre section are all on and bolted up, it's just about 3" short of the cat.... so I'll have to make up some scaffold tube to bridge that gap, handy given that the two are meant to slide over each other, so it'll have to be stepped.
no swages or anything over the rear beam, so it's a decent bore all the way through, the 1.6 one is comedy, I joke not when I say it is squashed to about 15mm over the axle.....
tailpipe exits straight out the rear, through the valence, so I did what I do best, used my favourite tool (angle grinder) to cut the trim enough, then rammed the tailpipe home fully expecting it to melt it's way into position when it's hot :)
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
To be fair hes not bad with a angle grinder, just likes to sheer of bolts when removing bumpers and snapping securing clips off of air box`s. :p:lol:
David.
WeeJase
pert
Jun 2, 2001
8,595
where is the website that you got the megasquirt from? the assembled one ready to fit into the car? very interested in one, would save me mucho wonga
cheers
its in this thread somewhere.and i can't be assed to go back 15 pages looking :p
hopkinsgm
Do-doo-be-do-do-dooo
May 25, 2001
2,030
Swindon (occasionally)
Visit site
...the assembled one ready to fit into the car?...
Assembled MegaSquirt's available from http://www.extraefi.co.uk/ in the UK - but when compared to the price of a DIY kit from the states, it ain't cheap.
Before seriously considering going down the road of programmable ecu's, I'd suggest having a read up on the subject - this is a pretty good primer http://www.amazon.co.uk/Engine-Mana...9994329?ie=UTF8&s=books&qid=1180259102&sr=1-1 though at times it reads like an extended advert for the Emerald M3DK ECU...
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
ECU's here, the kit is excellent - and the wiring loom is spot on. all individually labelled in the wire.
well labelled up etc, so won't take too long to assemble at all.
WeeJase
pert
Jun 2, 2001
8,595
so you'll be off to B&Q for a supply of no more nails. ;)
