G, is this for the Fiat, or the Ibiza? I'm sure once I've set mine up and I know it works I won't mind lending it out.
Anyway
remembered at 4pm I had an immobile car on the drive, so thought I'd best stick some bits on
Exhaust fitment is 'interesting' but the back box & centre section are all on and bolted up, it's just about 3" short of the cat.... so I'll have to make up some scaffold tube to bridge that gap, handy given that the two are meant to slide over each other, so it'll have to be stepped.
no swages or anything over the rear beam, so it's a decent bore all the way through, the 1.6 one is comedy, I joke not when I say it is squashed to about 15mm over the axle.....
tailpipe exits straight out the rear, through the valence, so I did what I do best, used my favourite tool (angle grinder) to cut the trim enough, then rammed the tailpipe home fully expecting it to melt it's way into position when it's hot
Anyway
