Phil_beeza Active Member May 15, 2007 461 0 Jun 20, 2007 #1 i have a gadget that has the red wire to +ve battery, and they yellow to the ignition, can anyone help? thx
joonspoon 175hp. 275lbs/ft. Nov 18, 2006 361 1 Oxfordshire Jun 21, 2007 #2 Phil_beeza said: i have a gadget that has the red wire to +ve battery, and they yellow to the ignition, can anyone help? thx Click to expand... Very nice. I have a gadget that opens tins. Do you really expect a useful reply? Regards Guy.
Nath. The Gentlemans Express Jan 1, 2006 8,615 16 EASTLEIGH, HAMPSHIRE Jun 21, 2007 #3 yeah I know exactly what you're on about................................not
Phil_beeza Active Member May 15, 2007 461 0 Jun 21, 2007 #4 joonspoon said: Very nice. I have a gadget that opens tins. Do you really expect a useful reply? Regards Guy. Click to expand... the clue is in the topic. do you know where the ignition fuse is located? many thanks.
Nath. The Gentlemans Express Jan 1, 2006 8,615 16 EASTLEIGH, HAMPSHIRE Jun 21, 2007 #5 it's in the fuse box
Nath. The Gentlemans Express Jan 1, 2006 8,615 16 EASTLEIGH, HAMPSHIRE Jun 21, 2007 #7 your question is a bit vague but I'm thinking you want to find a fuse that protects the key in pos 1 curcuit ? I really don't know the answer so have a look at the fuses and the inside of the fuse box lid for little icons to help you find somthing that works with key in pos1 but not with key out and test with the selected fuse removed be careful not to remove any airbag fuses as a trip th the stealers will be required to reset the fault light or as you say read the fookin' manual
ubiquitous Guest Jun 22, 2007 #8 Or you can buy an ISO connector/ wire it into the car's ISO harness. Got a PC running off mine (and 12v from the battery)
