__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Ok proberly a very quick answer from someone in the know, my k03s is on i just need to know what to do with the 2nd vac hose going to the actuator, ive spoken to m0rk and he thinks you just need to T it in to the other one, but ive searched and somebody else says you should block it off, so im a little stuck on what to do??
T it? or Block it off?
Cheers.
trace the pipe back it t's into the vacuum line from the valve on the top of the engine (cant remember its name) and the egr valve. either just cap the pipe off with a bolt or do it the propper way and trace the pipe back to where it joins, then remove the t-piece and put a straight connector in, or if your using silicone vacuum hose on the vacuum pipes just make 1 pipe the goes from the valve on the engine to the egr valve.
Ok mate cheers, im going to print this off and take it down to the tech tomoz, This is the first conversion they have done on the ibiza so was a little unsure what way to do it, it think they have t`d them into each other at the moment until i get back to him in the morning, What effect will this have if they are left t`d together?
No worries mark. Thanks for getting back to me so quickly anyway, ill call the garage in the morning and let them know what needs doing. Ill also let them know the proper way of doing it but whether they do it or not is a differant matter.
Cheers :D
