Remap V In line Tunit style box
olaf
Dodo Lover!!
Aug 19, 2006
1,081
29
Ipswich
Pete...
'With most serial downloads we use a coded custom key so that you can return your car back to STANDARD when ever you wish. ' What do you need to revert to standard then? What kind of figures are you getting from 150 PDs?
Thinking it might be worth the drive up to yours once I've got the clutch etc.
S3 AKR
livin' the dream!!!
Jun 30, 2004
1,453
Colchester, Essex
Just to give my experiences - I did my Leon at 5k miles with Revo and its the muts nuts mate! The clutch was OK for about 20k miles then began to slip so I slapped in an Allards plate which on the whole is fine but it has left me with some slight judder on take off if I try too hard to be gentle! You have to be a bit more "assertive" on pull away! Also it takes a bit of getting used to in traffic jams and in situations where you tend to slip the clutch. Due to the higher forces it doesn't slip so readily - as you'd expect.
You'll love it.
bellautos
Pete...
I dont use this system on the vag cars m8 .
From 35-40bhp depending on clutch the age of the car etc etc
Give me a shout m8 , im sure i can make it sing :D
