Bill's run's off the rocker cover:
what is a pcv
The Positive Crankcase Ventilation valve (PCV) is an emissions control device that routes unburned crankcase blowby gases back into the intake manifold where they can be reburned. The PCV system is one of the oldest emission control devices, and also one of the most beneficial. Besides totally eliminating crankcase emissions as a source of air pollution, the constant recirculation of air through the crankcase helps remove moisture which otherwise would cause sludge to form. Thus the PCV valve extends the life of the oil and engine. The PCV valve requires little maintenance.
