chase06
166
Hey guys,
Had a bit of a mishap today on the way home from work. I normally give it some welly on the slip road going onto the motorway (thats what Turbo's are for :clap: ) on the same road I go every day. Anyways, accelerating from 1st and through 2nd, pops it into 3rd and the FR 5 speed gearbox really shows how unpredictable it is. Crunch. But not any old crunch. Oh No. It was a squelching crunch, as if all of the lovely teeth on my third gear train are now gone. Now this woke me up somewhat, I normally switch off on the way home as im knackered, but this really woke me up. I felt sick all the way home and felt really angry at being such a tit. There has been loads of times ive noticed with this gearbox where it simply wont go into gear, and I always always catch it before I lift up the clutch, but today I had to be giving it a good boot when it let me down.
My questions are:
Is this now going to need a tran fluid change to get rid of those nasty shards of 3rd gear?
Has anyone else had this happen in any gear (normally always 1st and 2nd for me, but as I said I always catch it)
Have I done any damage to the gear train, and if so what do I do?
Im interested to hear everyones comments.
Cheers,
I think quality gearboxes have a magnet in them to catch all the little bits of teeth
don't worry but if you do then get the gearbox oil changed
this can be a clutch problem or gear linkage problem mate as if the the clutch is not completly disengaging and is still slightly toching then the gears will struggle to engage but this sound like it could be a linkage problem to me as its 3rd gear take it to the dealers and they will sort it out for you unless your mechanically known???
Hey guys,
seems to happen every now and again. its really bloody annoying!
Anyone had it before?
still could be your gear linkage! i have a problem getting some gears when my floor mat is under the pedal!!! as it does push down as far!
First time I got the car I found it hard to get it into 2nd, all my mates say the same thing as well. And the drivers floor mat is a pain in the arse if it get wet and starts to curl up. Can feel the mat when depressing the cluch, feels like the rubber has moved away from the pedal.
I've started having the same problem with mine from 1st to 2nd, anytime the revs build up a little I can pretty much guarantee it will crunch into second, which is mega annoying for stuff like round-a-bouts where you occasionally need to change quicky from 1st to 2nd to avoid having a car stuck in your boot. 1st to 3rd isn't really the same. I really hate to have to set off now as i'm so concious of it crunching into second which obviously isn't doing any good at all. Gotta take the car in this saturday so I will get them to check it and see what they think.
Mine occasionally crunches going into 6th, but doesnt really like 2nd when its cold, ok when warmed up though!
i get this thru first an second, hence y im goin down to seat on saturday......dont like it at all! ( gears that is )
Mine is kinda like a thud tho really, i think its the clutch not disengagin correctly. Pain in the arse if u ask me wen ur bootin it, feels like ur causing damage!
It really annoys me because I have no confidence to accelerate quickly in first then change to second because I know what will happen, not only is it not great for the car it makes you look like a tool.
Too true!! redline against a corsa or show off to a bird and then crunch**grind**...............embarassed!
Yeah it doesn't quite have the same effect when you blast off the line then 300 yards down the road you are parked up with your hazards on.
hehehe.............
Well hopefully ur only comin from the corner shop so can just say ur at home now!
self re-assurance!
It's got to be one of the worst noises in motoring, I think it's the only noise that when I hear it I actually wince.
I love my little baby car like, but the gearbox issue is something im not happy with. Im takin mine to seat on saturday morning in huddersfield. but its still under warranty and ive only had it 2 weeks so i think they need to sort it. Damn early appointment tho, cant b bothered wakin up so early!
Hearing the spokes of your alloy grind against a 6" high kerbstone comes pretty close I reckon :)
oh yes, i think that wins. u no your gunna more out of pocket if you knacker your alloy. More of a confidence drop when you know people can see how bad a driver you are. I say blame the wife!
