the two vents on the rear panel
Phil_beeza
461
with the floppy rubber hanging bits
does anyone know how these work
as in...if you're at any speed do they always suck air out the back? i assume they are to equalize pressure or something
ANdy947
Newbie
Mar 20, 2003
47
Visit site
Not 100% sure exactly which vents you're on about, but generally these things are to allow you to close the doors (by equalising pressure as you rightly assumed)
If the car is tightly sealed you seriously struggle to close the doors, unless you do it very slowly.
Phil_beeza
461
actually they might normally be hidden by trim
if you are standing looking at the tailgate with the boot open, and you pull the trim around the boot catch off,
there are two vents just below the catch
this might be a good place to put fans to chuck out amplifier heat
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
as said it's most probably to stop the windscreen popping out when you slam a door or the tailgate :)
these sort of vents normally have flaps on them to stop rain and splash from puddles geting in
R1ch85
1/4mile - 13.935 @ 100.54
Nov 9, 2006
1,675
Bristol
theyre behind the bumper.. when i had my crash earlier this year i took the bumper off and there they were.
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
as above people have said but il clear it up they are simply to release pressure in the car when closing the doors as if it was a tight seal the windows WILL SMASH and the doors wont close nicely! rubber flaps are just to stop drafts entering the car and water ect
