cupra2007
RCOTY
Jan 7, 2007
193
rhodes/greece
eibach's are on the car with oem dampers!their cost was 220e plus 150e installed and the car been geometry checked!it looks fantastic,the ride IS better,a little softer and more progressive than before!though when we checked the car after installation for geo settings we found that it was a little bit off the factory's settings especially the toe figures(mind you the differences weren:t due to fitting the eibachs)!!after the setting the car has changed dramatically!the steering became faster and more accurate,the car was understeering a lot now it's A LOT BETTER,and the spinning in 1st and 2nd was reduced A LOT!!all in all great purchase and i sugest you check your cars for correct figures of geommetry!:) some pictures from my phone:1) http://img470.imageshack.us/my.php?image=eibachcupra006ig8.jpg 2) http://img470.imageshack.us/my.php?image=eibachcupra002tx5.jpg 3) http://img204.imageshack.us/my.php?image=eibachcupra009eb0.jpg 4) http://img204.imageshack.us/my.php?image=eibachcupra004oa4.jpg 5) http://img204.imageshack.us/my.php?image=eibachcupra001ko0.jpg . cheers!!
sportline 2.0 TFSI Cupra 11.06 - code number(E20-81-009-02-22) front( 21-15-007-02-VA) rear( 21-85-014-01-HA ) 1130 kg 930 kg 20 mm 30 mm cheers!!
silly question.... but .. i thought the bi xenons came on the cupra as standard... and you havn't got the washer things on the bumper like on mine.. is it a foreign thing?
its nice and very low, you have just eibach springs and original dumpers right?
yes!!!great combination!!in the photo the height difference isn't big but on the car IT IS!! http://img223.imageshack.us/my.php?image=dsc00013ow7.jpg :) below i give you my geometry settings: LEON CUPRA :1) front axle:
Ολική σύγκλιση χωρίς φορτίο : 10Ά ± 10Ά
Γωνία camber (με ίσιους τροχούς)* : -41Ά ± 30Ά
Μέγιστη διαφορά camber μεταξύ τροχών : 30Ά
Γωνία caster : 70 47Ά ± 30Ά
Μέγιστη διαφορά caster μεταξύ τροχών : 30Ά
Σύγκλιση σε στροφή 200 και στις 2 πλευρές** : 10 40Ά ± 20Ά
Μέγιστη γωνία στρέψης εσωτερικού τροχού : 40Ά ± 10Ά
Ύψος (από τον άξονα μέχρι το φτερό) : 373mm
2)rear axle:
Μέγιστη διαφορά σύγκλισης μεταξύ τροχών : 20Ά
Γωνία camber : -10 20Ά ± 30Ά
Ύψος (από τον άξονα μέχρι το φτερό) : 375mm no translation though,sorry :doh:
Perfect ride height... Also, you can see on the last photo there is an extra coil..
Wouldnt mind a set of those for my FR TDi :D
Chris
Here's mine on prolines:
