Novel, but why are the gear cable selector 'holes' wonky? don't they need to be vertical?
(RR Saturday), So I'm going to have to try and build the TIP without it, then reinstall when it comes.
Good results Dave, did the car feel any stronger with the TIP.
Maybe the water injection requires rejetting, ie maybe too much water is being injected spoiling the burn....James's offer sounds tempting.
it's virtually irresistible.![]()
Can't think what you mean
Are you going to let "The lads from Dav" have a look at the logs first? I think your mods are pretty much textbook Stage3, so if you can run it on B9 T9 with the meth turned off, they also might be able to do something with the code. Also virtually irresistibly...
keeping discussion off jbs section.. the water/meth with no tune to support it did'nt make power on a power run on mine. short runs.. not like real use. it did allow me to dial in 12 degrees more timing tho, which is a shed load.
i used the smallest snow jet in mine. seemed near same water flow as 0.8mm aquamist but better spread of atomisation.
i recall vince at stealth commenting when he mapped 20vt converted cars on dta, for every 3 degrees more advance he saw 10bhp more. - significant gains
you can use unisettings on a usb vag-com cable to adjust your ign channel offset. that what i used, and fuel trims to remove some fueling to compensate for 50/50 water/meth "fuel". without this you drop power from overrich 0.75/0.65 fueling.
