Reverse light isnt part of MOT so its not all bad. Just a bit of a pain when reversing onto a busy road because no-one lets you out if they dont see them reverse lights!!
reverse light switches are always going on leons and ibizas. real easy to fit. remove fuse box cover on side of dash unscrew all t25 screws, then remove all the screws on the lower side of the dash section up to the centre console. then pull that section of the dash away and the brake light switch is visible. unplug it and twist it anti-clockwise about 1/4 of a turn and thats it! opposite to fit! though the fault code will need to be erased as it is stored under engine electronic memory content.
