why you say that mike? i didnt wake up one day and think..."hmmm, i think im gonna blow my engine up today!!" lol :)
Hi... plese send me info about >>got the engine mounts (i went for road rear and gear
got the engine mounts (i went for road rear and gearbox with race front) and cambelt part (belt, tensioner, water pump and damper)
see pics
got gearbox, clutch and flywheel off just waiting for new diff and clutch
HoocH
Hi......:funk: plese send me info about >>got the engine mounts (i went for road rear and gear >>> from my car Ibiza 1.8T :confused:
Hi... am need from .mu car ..tampons....engine !!
hi... am need tampons .. from engine / complekt 3 p...
or big brembo .. 305mm disk and 4calipper aparat....:confused:
thanks advans ...
best regards ..
Miro
you need tampons? are you a women then? i cant help you with them, sorry
but i can help you with brakes and engine mounts...
click this link tts
find alex at tts he can help you with all you need :)
they are valid items on full on engines... the pictures show this one bolted up, but obviously the sump needs to bolt up on the same holes..
sealing the sump might be a little trickier.. and the fit would certainly have to be checked and pinned, not just relying on the bolt clearances to align it to the rotating parts (ewww)
the lower girdle eurospec sell combines block strengthening with a scraper of sorts.. and has proven to be tricky to install & seal
