marky t
300 horse+
May 5, 2005
118
nth. lincolnshire
please can someone help. my ecu has died am now undecided which way to go with it. i dont know weather to go for an after market ecu or try to find another ecu and get it re-mapped to suit the new big turbo which i have ready to fit any ideas
what make sure the ecu has failed? never herd of an aftermarket ecu, if you get oem ecu, you flash it, the forum sponsor do a good job with great figures
car cut out and wont start vag com shows no ecu found. an after market ecu simply replaces the standard one but doing this you can then map the car yourself using a lap top and also it gets rid of some of the little niggles like you can junk the proplematic maf sensor and also then get big power if you want
very interested in the aftermarket ecu idea, but never heard of one!! what the situation with matching the dials/immobiliser up aswell then?
ECU`s are not common to go
If you replace with an after market one you could get more issues than you think
I would double check first
The only one I heard of was a problem with the dash pod
Replacing the ECU will not get rid of a problem like that
If you disconnect the MAF you will not have any air flow readings , so how will fueling be adjusted :confused:
Sarah
Sarah
Hi Sarah
It is possible to change the ECU to an aftermarket version and remove the MAF.
Fuelling is set within the ECU, so the MAF can be removed.
We have worked on some of these when fitting the 1.8T to MK2 Golfs, and kit cars.
Mmmm
I will believe you , I have not seen any on a modern car that should have one from standard
Never mind if it runs better
My main concern though is that someone else is going to be told their ECU is knack`d and replace it still to have the problem there
I would not go for a stand alone one until you know for sure it is duff
I must admit though p-torque when you do another one if it is on a modern car I would like to know
Be good to see as then I can advise people from then on
Sarah
mostly aftermarket ecu's are used on higher power cars so that they can be mapped exactly to the users needs there are loads of different ones out on the market but they are all quite expensive
Mmmm
Sarah
Hi Sarah
They are commonly used on high powered Turbo Japenese models, which dont use a MAF.
We have a demo MK1 Jetta fitted with a 1.8T, and thats running an aftermarket ECU.
I agree with you though, ECU's are very unlikley to fail unless they have been subjected to water.
