Thinking In Changing My Fog Lights To Hid........ But I Need Advice In Which Brand To Buy, And Installation Tips, How Many Kelvs...........really Thanks
www.hids4u.co.uk
I've used them before for OEM Xenon upgrade to 6000K in my Fabia vRS.
Good service & cheap too.
Personally, I wouldn't bother fitting HID's in the fogs.
OEM Xenon upgrade? what did you have done and why?
They aren't.Those lights look really good.. would never tell they an after market job.. How do they compare to factory fit xenons in the flesh? do they perform as well?
The standard Fabia vRS Xenons have 4300K bulbs on dipped.
I upgraded to 6000K bulbs.
Then later, fitted H7 HID conversion on the main beam
Dipped:-
HID main beam:-
No, the K rating doesn't mean more power, you've actually got more light output from 4300K than from 6000K. 6000k just gives you more of a blue light than the OE yellowish one.
The projector lens combined with 4300K will give a whiter light, 6000k with projector lens will give a bluer light. 6000k with a reflector lens will give a blue / white light. 4300k with a reflector lens will give a yellowish white.
The projector lens units add a slight blue tinge which is why OEM Xenon / HID use 4300K and not 6000K
So was there a difference on how they performed on the road? The HIDs 4u website reckons (as does UF) that they produce less useable light, so was it a purely aesthetic mod?
hey elduke ;i bought Xentec H.I.D s , and fit perfect i try ones of my friend, and order it today.
http://www.amazon.com/XenTec-conver..._1?ie=UTF8&s=automotive&qid=1195458675&sr=1-1
some pics of the fog light
