gib9060
hi all hope some one can help im after some braided lines for my ibiza gti 16v but as its the 16v its fitted with the 280mm brakes i carnt seem to find lines for it goodridge only list lines upto 1996 with the smaller brakes does anyone know if they have the same fittings or knows anywhere i can get some braided lines. thanks again :help:
If you want long lasting (relatively speaking) stick to OEM lines. If you want more protection and performance try synthetic cloth braided lines (if anyone is specifically marketing them for the NSX I don't know; if not, custom made by a fluid fastener maker is an option if you can find someone willing to make them for you). That last comment is an option not a recommendation.
interesting read..
how long should normal brake lines last by the way?
thanks for the responce guys i checked the part numbers online and it looks like goodridge may fit i will phone my motor factors and see if the oem part numbers are the same. will let you know what ii find out asap :)
Should be able to do you a set of lines for around £50 if you are interested,they are made to order as well and normally only take around 3days to ship as well,let me know if you are interested.
yes m8t i would be interested can you tell me what fittings and sheeths you use cheers ;)
