Powerpuffbabe
Hi All
My first post, so be gentle! I have a 1.9Tdi 2003 Ibiza and the hazard light has started glowing in the dash. I think I’ve found the power steering reservoir and believe that I need to top it up (please see attached photo).
Can someone please confirm that this is the reservoir and that I can un-screw it and fill it with fluid?
Thanks all
Ju
If you have a look in the manual it will tel you which one it is mate.
And welcome to the site my friend :wave:
no sorry thats the oil filter, the reservoir for power steering is infront of the battery and has a green rop not much bigger than a coke bottle top.
The warning light you have on on the dash if its a coil light/warning light that looks like a piece of twisted string then check your brake lights ar working. the coil light comes on,on a diesel when there is a fault
as said that's the oil filter, look for a green lid below and to the front of the battery, sort of hehind and down from the passenger side headlight
what light on the dash is glowing exactly a pic would prob help :)
Hi All
Thanks for the replys, I've attached a picture of the warning light.
The only manual I have is the small book that came with the car and it really dose suck!!
Ju
yer the sensors always play up. Mine does it now and so did the last one often have to stop and restart the engine, however on the new one I dont get a light come up it just doesnt work
Isn't there a known fault that affects the power steering on Mk4 Ibizas ?
I can't prove it but-- having had the lamp lit in ever warmer conditions over the last 3-4 years starting @ colder than -3degC and each winter moving to a higher temp now+5 I believe it's a lack of voltage, despite easy first touch starts, when the glowplug lamp goes out, in approx2-3 seconds the aircon fan will switch back on if you then hit the starter no power steering lamp:redface: the level should be tested on the dipstick but there is a laking on the res' a torch BEHIND it will help:)
notmally its water ingress into the steering angle sensor which is located on the rack underneath the car
