brake upgrade on TDi
the bear1986
323
norwich
hi quick question what do i need to get the full audi tt brake set up?
as does anyone know if brambo has done a brake set up for the mk4 tdi?
Deleted member 13581
Check on Ebay for the full 312mm brake conversion kits. Theres always some on there.
These upgrade kits will only work if you have a 130 TDi as the hubs are different from the 100TDi and the kit wont fit.
muddyboots
Still hanging around
Oct 16, 2002
5,739
Assuming you have a PD130, you need:
Calipers from Audi TT, Leon Cupra, Audi S3, etc
Carriers
312mm disks
Pads
You can just about get away with using the original hoses.
Tall-Paul
Previously ph2858 :D
Nov 12, 2006
671
Manchester and Preston
Braided hoses are supposed to make the brake pedal less spongy as there will be alot less 'give' in the brake lines as the orignal ones expand a little. You've got to do the rears as well to make it worth while.
muddyboots
Oct 16, 2002
5,739
I was referring to hose length; I kept the original hoses on mine, they just about reach the new calipers OK. Some of the kits you see for sale off Audi TTs come with the hoses as well.
the bear1986
323
norwich
i have the tdi 130 i have seen that kit on the vag website but i didn't know if that was everything i needed?
so is there a brambo kit out there or is the ttset up all i've got?
mrcoyote
See no evil...
Jul 26, 2004
2,624
Yes there is a Brembo kit and also the Seat Sport APs, but these cost substantially more than the TT 312mm setup and you'd probably need new wheels to clear the calipers which means additional cost.
Deleted member 12466
Bear its BREMBO!!!!!! not BRAMBO RAMBO!!!!!!
Spell check LOL!!!
depresion
484
Pressure in a fluid acts equally upon all sides longer hoses theoretically shouldn't make a difference, but longer hoses will effectively give more, though unless you are talking about adding a substantial length then it shouldn't be noticeable.
muddyboots
Oct 16, 2002
5,739
It was nothing to do with fluid quantity, but the ability to attach the hose end to the caliper :)
