Problems starting Cupra (remapped)
Saul
<b>SCN Admin</b>
May 21, 2001
4,194
did you have a trial revo map before hand, ive heard trial maps lock ecus like this?
they dont lock out the ecu, some 'tuners' have limited software and blame it on something else
as for the orignal poster, i doubt the maps at fault, but never say never.
i take it it will turn over just not fire?
Swany
it turns over for about 5 secs then it fires
G!zmond0
It's the remap man.Sorry to ruine your high but that's the problem.I had the same issue with my P.Box.It didn't want to start.It even stoped working while the car was in motion.After I removed the box the car was just fine.It started rightaway.If you inputed software though i dony know, maybe you should talk with the remap company.Don't worry i am almost certain it's the remap
Swany
Have you tried disconnecting the battery to force an ECU reset?
Has it done it since the remap was put on?
Can you smell fuel at all?
have not tried to disconnect the battery.
it strted about 3 weeks after remap was put on.... def cant smell any fuel
G!zmond0
I sent my box back to Germany and the people replaced it with new one.I installed it and it started just fine.It's the remap
Saul
<b>SCN Admin</b>
May 21, 2001
4,194
i agree with m0rk, sounds like a fuel issue
Custom-Code HQ
Hi Guys,
Let me just clear a few things up on here.
We did the remap and after it was done my mobile agent checked logs on the car to make sure everything is running perfect (which it was) - this was done via VAG-COM after the remap so if there was any issues trying to communicate with the ECU it would have been picked up here.
Personally I believe the dealer is just trying to fob you off, as I have worked at a Seat dealer I know how they work :(
As I said to you, we will be more than happy to check over the car to point you in the right direction and give you advice. This would mean coming to us or local agent, which I have tried to book an appointment.
It sounds to us like you are loosing fuel rail pressure over time, check to hear on the first stage of ignition the in-tank pump is working. Sounds like you are having to build fuel pressure before the engine will start.
We have never had this problem before with any other Leon’s we have done; I hope you can get it sorted asap!
Kind Regards
Custom-Code
G!zmond0
I don't think it's the pump.If it was the pump the car would start and after that it would strart breaking untill it stops or it would not start at all.
Custom-Code HQ
Hi
You do realise this is a DIRECT PORT INJECTION ENGINE. And not a 1.8T
The original post reported having to crank before it fires , This is quite normal its due to the rail pressure having to be built before the engine is allowed to fire. (unlike a 1.8T it uses a mechanical fuel pump to supply the injectors) and over time the pressure will drop, and need to be built back up in order to start. I bet if you start it from cold it will do it every time , then turn it of and restart ,now the pressure is pressent you will find it start firsts crank. It also helps some if you pause between first stage ignition "electric pump fires" and crank.
Hope this helps
CUSTOM-CODE TEAM
Swany
Hi
Hope this helps
CUSTOM-CODE TEAM
This is exactly what is happening, it is worst first thing in the morning when the car is cold but if i go a run to say the shops then come back out to start, it more or less fires first time. I have tried to pause between ignition and crank but it does not make any difference. I can def hear the pump working though... What is causing this then..?
honeyman
Pirates
Oct 20, 2004
614
Northampton
Although mines not as long as five seconds I do have to let it crank before it starts in the morning it always been like it pre and post remap.
