Got home & part 2 of the new look grill had arrived
So I thought I'd do a little write up on how to remove the grill & fit it.
The grill is quite easy to get off, if you know how (I've had the grill off a few times now)
Its held in at the top by two expanding plugs, easiest way of getting them out is to use two screwdrivers & lever the top part of them out
Exhibit A - The retaining plug thingy
The grill also sits under the slam panel in its own little groove
The grill is also held in place on each side by two clippy things, best way of releasing these is with a long flat screw driver, try & ease them out gentle, maybe a squirt of WD-40 to help. (cant believe how dirty its got in a day)
The honeycomb section is held on to the main grill by two very small self tappers
The finished article
