CHR15B
2,560
Scotland
Just a little discussion thread to highlight out the little MK4 specific niggles that nearly each one suffers from or is likely to suffer from! :D
I'll not go and list them all as thats what each person can do... try not to go and list them all but I'll start a ball rolling with a couple...
The interior rattles like hell and the windows rattle when they are down and your driving!
1. Yep, the windows rattling when down is very anoying.
2. Interior rattles
3. Drivers door solinoid (just had it replaced)
4. Radiator prone to cracking (just had it replaced)
You know you have a MK4 Ibiza when...
you look at your car and notice its a MK4 Ibiza :confused: :cartman:
Also,
When the windmirrors over-ride the I.C.E for noise polution
rear washer jet pops off
when you open the doors it doenst stop in stages and you nearly prang the car next to you!
the radio never tunes in properly
You destroy your hands changin bulbs (well on a diesel you do!)
random lil bits they forgot to put on your car in factory like boots light, glove box light, mini sun visor, battery cover, engine cover
The climate control never goes to the temperature you set it to.
25c .. two clicks down .. 24.5c .. 1 click down .. 23.5c .. 1 click up .. 24.5c .. settle for 24.5c
when all your coils pack up! (on my old 1.2)
when ur timing chain snaps! (on 1.2 12v. although mine survived)
The climate control fan speed never stays at what you set it at. Adjust temp and the fans have a minde of there own!
Actually that is my number 1 annoyance [:@] As soon as you drive away, the speed goes up like 2 notches. And then you have to turn it down while driving without turning it too far and turning it off. Then when you turm it back on 1 notch, it comes on too strong..
As said you get a boot full of water when the washer jet pops off.
You carry a spare set of clips for the boost pipes just in case they pop off.
The air con fans go full tilt just because you selected reverse.
You look at your car and know its better then a common Corsa!
your passengers rip their door handle off
the door cards rattle to the beat of the music
it takes 12 clicks to unlock your boot
